C5 auto tranny problem
The tranny has been great untill i got it tuned on the dyno (the converter was unlocked btw). After a pull I thought the rollers were stopped but they were still barely spinning and I got the awful gear grinding noise for a second untill i dropped it back down to neutral.
After the pulls I went to drive it home and it was acting really weird. It revv'd up and took off like it was on a delay and after I came to a stop to turn it wouldnt do anything. Acted like it was in neutral no forward or reverse. After a couple minutes of playing w/ it, turned the car off etc.. it finally took off and made it home. The entire trip was maybe 2 miles. The other day I backed it out of the garage and when i went to pull it back in the car didnt hardly want to drive over the concrete lip into the garage.
Is it something as simple as the shifter linkage popped loose or what? The tranny has been great, never slipped or missed a shift so I dont beleive it burned up on the dynp w/ out notice. It never got very hot or slipped anything.
Also if its the linkage or something similar can anyone give me a quick walkthru how to check it?
Fluid looks fine.
Today I put it in reverse and heard some noise from the rear like something kinda binding up. Like the e-brake was on, revv'd it up and it moved about 6inches and I lost reverse. It wouldnt engage at all just like it was in neutral. I put it in drive and the car jumps like it engages fine. But I was in the garage and couldnt back up to try and move it much in Drive.
Originally Posted by performabuilt
Sounds like you may have a stripped sunshell
Can you go into some detail for me please?
The way it sounded on the dyno was def. parts grinding. Would it also cause drive to be in and out?
Anyway to tell for sure? If so I need to get going on it. Im assuming it would need taken out and torn down to replace it. Is it something where only the sunshell would need replaced or does it usually take parts out w/ it too? Sorry for the load of questions just trying to figure it out so I can get it running again asap. Thanks for the help!
