Overfull 4l60e what will it act like
Old 04-07-2007, 11:21 AM
THEE PEWTER Z™'s Avatar
Default Overfull 4l60e what will it act like
i just got the car back and i think its way overfull. Not to the point where its foaming but... Any ideas what the trans will act like... It doesnt want to downshift and the car just feels like a slug
Old 04-07-2007, 11:24 AM
LS1Tech Sponsor
performabuilt's Avatar
Down shift are controlled electronically , Overfilling would cause foaming and soft shifts , But it would have to be ovefull by a considerable amount. Sounds like you have some kind of controll issue do you have a scanner or tuner?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-07-2007, 01:16 PM
I have an autotap but havent read it yet. there are no ses lights on or anything. When i check the fluid its about 3 or so inches up on the stick above the crosshatch but no foaming..
I had it tuned a while ago and never had a problem. but i did brake the tailhousig about 800 miles ago and the dealer rebuilt the trans...
Old 04-08-2007, 01:38 AM
Problem solved......... Inline t-rex fuel pump must have been overfueling or holdin pressure back not alowing the car to make power.... Removed it and now im all good. Swore it was a trans problem
Old 04-08-2007, 10:09 AM
LS1Tech Sponsor
That happens more than you know, We help people all the time with problems they think are trans issues that turn out to be a whole array of different things. And more that a few transmissions have been replaced and rebuilt in error I have seen in the years I have been doing this.Its a good thing you took the time to work with it a bit and figure it out. Glad you got it solved.
__________________
Call 888-744-6542
Old 04-08-2007, 11:02 AM
Well whats nice is havin sponcers like yourself on here at all times of the day to answer q's... Small things like that is what makes a bussiness worth dealin with...
Quick Reply: Overfull 4l60e what will it act like
