T56 to Th400 what wiring do you hookup
Old 04-23-2007, 06:30 PM
azibit's Avatar
Default T56 to Th400 what wiring do you hookup
what wire's do i run where i have a b&m prostick with a neutral saftey and need to know what wires need to go where can anyone help or lead me in the right direction...........
Old 04-26-2007, 04:06 PM
98turbls1's Avatar
x2...
Old 05-02-2007, 11:04 PM
azibit's Avatar
bump....
Old 05-03-2007, 01:19 AM
revtime's Avatar
Not sure if the LS1 cars are the same or not.
On my 94 I just spliced the nuetral safety wires together so it should not matter which nuetral switch wire goes on which end of the switch.
You will need a backup lite switch as well. Mine are not hooked up at all right now but reverse lights are not that important to me as I don't drive the car on the street much.
I think once the nuetral safety switch wires are spliced together you should be able to drive the car.
Again though I went from 60E to TH400 not a 6 speed.
Old 05-03-2007, 11:30 AM
LPTXZ28's Avatar
Here is a thread on this I had bookmarked. I have not tried it but sounds like what we need.
https://ls1tech.com/forums/automatic-transmission/604012-th4oo-swap-weekend.html
Old 05-03-2007, 03:09 PM
blkbird_WS-6's Avatar
LPTXZ28, I knew I posted in that thread, you just saved me from having to dig it up. Thanks.
azibit, all the info you need should be in that thread.
