1992 4l80e...after 60 mph no 4th gear
Old 05-17-2007, 12:11 PM
crpjaviman1's Avatar
Question 1992 4l80e...after 60 mph no 4th gear
Hey guys,
I have a 1992 K2500 with 4l80e tranny. I recently changed the 1-2 shift, 2-3 shift, TCC and pressure solenoids. My previous problem was that when it shifted, it shifted HARD through all gears.
After installing the first set of solenoids, I noticed that the tranny worked find under 60 mph. I get on a straight away and slowly bring it up past 60 and the fourth gear downshifts to 3rd. I thought it was the solenoids so I changed them 3 times. The last time, I bought the set from a local Chevy dealer but still have the same problem. I can reset the computer and it works under 60. I scanned the ECM and it gives me two codes:
Overdrive faulty or failure (don't remember right now)
QDM fault.
Within these forums I learned the QDM is in the ECM. Can I get this flashed and the problem go away?
If any one can help me shift correctly, I would appreciate it.
Thanks
Old 05-19-2007, 11:19 PM
LS1Tech Sponsor
performabuilt's Avatar
What code is it giving , In this trans the PCM will not allow fourth if lockup does not occurr or if theres excessive converter clutch slip
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-21-2007, 10:36 AM
Since my last post, I changed out the ECM and the speed sensor on the tranny. The previous codes were as follow:
68 - Overdrive fault
8? - QDM fault.
After the ecm and sensor change, I only receive the 68 code. Similar to the previous problem, after changing the sensor, the tranny downshifts now at 65.
I have been told that it is a sticky valve in the valve body. I added Lubegard to the tranny to try to free whatever valve. I read somewhere that there is a screen within the v/b. Could this cause this problem?
Let me know.
crpjaviman
Old 05-21-2007, 10:41 AM
Curious thought....my engine revs a little high throughout. For example: when fourth was engaging, my RPMs were 2500 to keep up at 65. I am comparing to my 95 sub which runs 2000 at 70 steady.
Just a thought.
crpjaviman
Quick Reply: 1992 4l80e...after 60 mph no 4th gear
