Stall Install
Stall Install
I am installing my stall soon and need to double check on tools/procedures. I know I will need some swivels, and a 24" extension.
Basically, I am thinking....
disconnect driveshaft
disconnect all electrical sensors I can reach
remove dipstick(should I remove from the motor, or just let it slide out of the trans when I drop it?)
disconnect shifter(do I disconnect it from the interior, or under the car?)
remove bellhousing bolts
remove cross member
As far as removal goes...When I remove the trans, should I take the stall out with it, or drop trans and then stall? And should I install the stall on the trans, or the flywheel, then the trans?
remove cross member
Your going to need a really long extension. I had to use every extension I owned all strung together to get the length needed. The last 2 transmission installs I have done all by myself but it really helps if you have someone there to help you out.
Good luck.
If you install them together, how do you go about bolting it to the flywheel, spinning the motor with a socket? Or a flywheel tool? Or just cranking it?
I have a tool that spins it but in a pinch you can use a big *** screwdriver. Just be careful with it.
