trans experts needed
Hello, I am in the process of rebuilding a 2000 4L60E and have noticed a few oddly worn parts. First off, the low/reverse drum has some slight scratches/scoring from the belt. Is standard procedure to sand or replace? Also the the input drum (3/4 clutch housing) the outside aluminum teeth show slight wear as well. Replace or reuse?
LS1Tech Sponsor
Good advice and make sure there are no gouges if the lining has come off the band the surface must be relativley smoothe
Originally Posted by Predator T/A
put a staright edege across the reverse drum if you see dayliht under the straight edge replace it.
__________________
If the input drum has wear on it from the reverse input frictions you might want to get a new one. I have seen in some cases ,not many, where the reverse apply is not working correctly due to the hub being worn. Also you should look inside the reverse input drum for wear from where the steels ride and also where the cushion plate rides. These do get worn out in time and I install a new drum in almost every unit that I build. Good luck with your build. Vince
