HELP! Torque arm Clamshell bushing unremovable? Picture
Hey Guys,
I my replaced my BMR torque arm with the stock one. I went to install the new clamshell bushing and the bolt wouldn't clear the body for removal. So I removed the driveshaft and transmission crossbrace to lower the transmission and it still wont clear! I let the transmission hang as low as it would on its own. It won't go anylower on its own and I feel like if I force it I will break something. I didn't think it would be some much work to replace this bushing. Do I need to remove the transmission to replace a torque arm bushing!? You can see in the pictures how it is hitting the body and how long the bolt in on the one that needs to go in.
THanks,
Lane
THanks,
Lane
Usually the trans will drop enough if it's not held up by the exhaust.
So you need to jack it up from somewhere other than the tail housing and unbolt the tail housing.
Six bolts.
Six bolts.
