Can you still hook after putting in a stall?
Old 07-29-2007, 08:17 PM
allbaugh_04's Avatar
Default Can you still hook after putting in a stall?
I got some nice 245's that hook nicely the way the car is. I'm guessing after adding a 3600 I won't be able to anymore. Does a stall make a huge difference after installing it?
Maybe tell me your before and after stories?
Old 07-29-2007, 08:23 PM
White_Ls1's Avatar
I say you do it just to find out, Then Go with some 315's!!! I have 275's with a 2800 stall, 3:42 gears and they don't do so well. The story before the stall was, they didn't do so well
Old 07-29-2007, 08:44 PM
Travis99LS1's Avatar
I have a 3000 stall..I only have 245's in the rear..but it will spin right thru first at anything more than about 1/2 throttle...I have some BFG drag radials that i use at the track..I'm sure they will hook pretty well..but i'm scared to put them on cuz i dont want to blow my rear end up again
Old 07-30-2007, 12:35 AM
transamfreak01's Avatar
get a good tire. go wit a mt et street radial. youll hook just fine with a nice burn out
Old 07-30-2007, 11:07 AM
HaulinHawk's Avatar
As nike says 'JUST DO IT'.Just run a stickier tire.
Old 07-30-2007, 11:52 AM
jmm98LS1's Avatar
My 3600 stall would vaporize my old 275/40/17 street tires anywhere in 1st gear and halfway through 2nd. Now have 315 bfg drags that hook very well on the street. Unless you like smokeshows, you need drag radials with a big stall.
Old 07-30-2007, 04:39 PM
I guess I have severely under estimated the capabilities of a stall. Is there a big write up on exactly everything a stall does for you. I've searched on google and came up short.
Old 07-30-2007, 06:25 PM
omcar's Avatar
Do it..some suspension mods and tires will allow you to hook.
Old 07-30-2007, 07:22 PM
I'm eventually going to get stiffer, lowering springs, along with stiffer shocks in the back with new tires...275-295..somewhere in there. Will this help or make it worse.
Old 07-30-2007, 07:25 PM
Trunion King
bene's Avatar
At the track, I got a few 1.8-1.9 on my street tires (18" wheels/279 BFG rear tires). At the street, I can't launch pass 1500 rpm w/o spinning.
Old 07-30-2007, 07:45 PM
5_02ls1's Avatar
my car with 3.73s hooked good with the stock stall if you wanted to....now its halfay through 2nd before it even tries to move....so id say get sticky tires.....i have et streets i use at the track....
Old 07-30-2007, 09:40 PM
sixvi6-camaro's Avatar
That will make it worse. Don't expect to hook on stiff suspension because you just won't get the weight transfer needed to do anything.
Old 07-30-2007, 09:44 PM
Well I really want a stall but now I'm not sure if its for me. Not sure I can get the look I want without lowering it and now this is a negative mod for the stall.....
Old 07-30-2007, 09:55 PM
RocketCutlass's Avatar
my stall and my power with stock tires means i have to be going above 80 to floor it, 65 with the 315's on it
Old 07-30-2007, 09:58 PM
damn you all....ur making a tough decision for me with all these great stories
Old 07-30-2007, 10:13 PM
Stall is a blast overall and well worth it regardless! Just don't be thinking you can road race the car with a huge stall because it will break traction very easily.. Just as you can't expect to run 1.5 60' times on stiff lowered suspension. a high rpm stall is more a drag strip mod.. lowered stiff suspension is road racing.
Old 07-31-2007, 02:23 AM
99DWPTA's Avatar
just got my 3600 in and lovin it
Old 07-31-2007, 03:29 AM
DSkyles's Avatar
M/T et sr's ??? and you don't really have to do a big burnout to get them to hook. Just a little one and as soon as you see tire smoke haze you're good.
Old 07-31-2007, 10:54 AM
bjamick's Avatar
I used to hook on my BFG DR's on motor, then right when i put my 3500 PTC stall in i couldn't hook in first without peddaling it through the gear .. I need some slicks.
Old 07-31-2007, 11:40 AM
Yea, but isn't it true when you start launching on slicks..ur just beggin for a broken rear end?
