want to see ratchet shifters installed
#81
This isnt a 4th gen, but it might help
Pro ratchet stealth and just made a plate to bolt it onto stock location. Maybe an automatic 4th gen consul will fit like this?
#92
Most of them will work with a little bit of modding....the bracket that bolts to the pan bolt holes needs to be cut and welded to match the 4l60 bolt holes, and you have to use the correct holes in the "boot" shaped peice that bolts to the selector on the side of the tranny. Also you need to be sure each gear shift puts the selector into each gear and not between gears.
#93
Just ordered a B&M Stealth pro ratchet to go along with the performabuilt stage 2 4L60 with a manual valve body and 3,400rpm stall. Ill do a write up and post pics. Going to try and keep the a4 center council if i can
#94
If anyone is interested in keeping the stock A4 shifter I was able to modify mine to work with a RMVB. I pulled the shifter and modifyed the gate so that it locks into 2nd gear then to switch to 3rd you push the button. I also welded in a stop so that after 3rd gear it won't go any farther back since I use a TH400. I love it and I didn't have to hack up my console because I still use the stock shifter. If anyone is interested and has any questions let me know.
Thanks!
Donnie
#95
Who ever has a b&m hammer with a m6 console i need help. I installed mine and the console doesnt clear it at all. Also i have a problem adjusting the cable i cant get it into park and if i adjust it so it goes into park then it wont go into drive. Last i cant get my reverse lights to shut off what is wrong!! Did anyone have a problem with the pro stick i may just buy that one?
#98
