want to see ratchet shifters installed
#125
#127
What pictures would you like to see and I will see if I have any. I still plan on putting some of the stock indicator parts back in as well. It's a tight fit but I think I can make it look good.
#132
Cable
I have a pro ratchet I'm trying to install and can't seem to figure out a good way to route the cable. I have both the 5ft and 3ft cable and between routing it and getting the hole drilled in the right spot I can't seem to get it all together. If you or anyone could help me on the routing I would appreciate it.
#133
im planning on installing a th400 with full manual reverse shift and was curious if anyone here still makes either/both mounting kit and label/indicator? i found a b&m quicksilver ratchet shifter with rever but the part number is 81125 and i dont know if it'll fit in my 4th gen or not?
#134
