LT1+4L60E -will 168 tooth flexplate fit?
Old 08-09-2007, 04:22 PM
chief455's Avatar
Default LT1+4L60E -will 168 tooth flexplate fit?
I have a starter fit problem with my Canton oil pan and the starter grinds.
If I switch to the outer diagonal mount holes on the block - that type starter has lots of room.
Can I pull out my 153 tooth plate and fit the 168 tooth in the bellhousing?
I have a 168 tooth plate a guy had behind a 383 w/TH400 but the weight was ground off.
Is there a an LT1 crank mount pattern, 168 tooth external (weighted) flexplate that will fit my 4L60E? and allow me to use the outer starter bolt location?
Old 08-10-2007, 02:00 PM
chief455's Avatar
anyone?
Old 08-12-2007, 12:11 AM
matt94z's Avatar
I'm not sure about the 168, but I wouldn't use it since the weight was ground off, it would probably kill your bearings since it isn't balanced for your motor. Why not just shimm your starter or by a mini starter for a 153 tooth flexplate?
Quick Reply: LT1+4L60E -will 168 tooth flexplate fit?
