I cracked my flywheel!
Old 08-12-2007, 02:18 PM
HossZ28's Avatar
Default I cracked my flywheel!
I took off my starter because it was making a weird noise and found this. The little gap in the flywheel is the crack and it goes about 2" inward towards one of the bolts.
I am going to change it on friday. I would like to know any tips I should know before tackling this project, like in removing the transmission, torque converter, or the flywheel. Also, the flywheel is just bolted on, right? This is the first time I am going to take my tranny off so I have no idea what to expect.
Old 08-13-2007, 04:19 AM
1999Z28's Avatar
If the transmission has never been out before. You're really going to want to heat up the 3 torque converter bolts. The locktite from the factory is MEAN. lol.
Make sure you order a "Flexplate" for your car...not a flywheel.
Old 08-13-2007, 10:27 PM
HossZ28's Avatar
I didnt realize it was a flexplate. But why would it crack like that?s That is a pretty thick piece of metal to just split like that.
Old 08-13-2007, 11:40 PM
sixvi6-camaro's Avatar
Mine was cracked around 2 of the bolt holes for the converter. 00 and newer flexplates are known for cracking.
