stall question
Old 08-14-2007, 08:22 PM
drewbster's Avatar
Default stall question
Will a stall make the car pull harder from a roll?
Old 08-14-2007, 10:14 PM
sroach20's Avatar
yeah, cause it will put you higher into the power band.
Old 08-14-2007, 10:56 PM
LS1Tech Sponsor
performabuilt's Avatar
Yes it will as mentioned cause the engine to stay in its power band very benificial
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-16-2007, 05:18 AM
tiresmokeLS1's Avatar
With a very efficient converter with a low STR, you will even pick up rwhp vs. the stocker. So the benefit is two-fold. Your dyno chart will read higher in every gear, plus, you'll drop less rpm between shifts, keeping the engine at a higher torque point.
A very huge converter can still slow you from a roll, but still drop ET, since you'll be off the line much quicker.
Old 08-16-2007, 01:03 PM
drewbster's Avatar
The old converter was a TCI 3500...I just put a new motor in the car along with the stock converter..Cant beat on it so i was just wondering if its gonna feel slower without the stall
Old 08-16-2007, 01:14 PM
LS1Tech Sponsor
yes it will tend to feel slower after you have gotten used to the stall
__________________
Call 888-744-6542
Old 08-16-2007, 01:30 PM
drewbster's Avatar
But will the car actually be slower? Or do you think the stall was too big for a stock motor? I know the car will not run as low an ET. MPH wise though hows it gonna do? Around the same as before??....I dont beat on my car from a stop much..Dont wanna **** up my rear end ha
