largest cam on stock converter
i know this sounds stupid but i am doing a head and cam swap and i am going to change the converter a couple weeks after i do the swap but i was wondering if i went with something like a comp 224/230-581/588 lift would that stall out on a stock converter???if so what cam would u pick thanks
What do yuo mean by "stall out on a stock converter"? I think you mean will the engine not run properly and the PCM has to compensate for the low stall.... if so then the answer is yes, the engine controller will most likely try to adjust the idle speed when it goes into gear.
But a good tuner can work with that condition.
Why not wait and do it all at once then get the package tuned properly?
g
g
