I do have a Body mounted T/A! I have a solid rubber mount that does not allow for any movement. I did not even think about checking the pinion angle for that . I wonder if that might have anything to do with it also.
Undoubtedly pinion angle can cause chassis vibrations!
Especially when coupled with the mounts you are running. I've fixed more than one car with wicked road speed vibrations by setting the pinion angle before.
