ls1 to a 700r4
Old 12-16-2007, 09:21 PM
RIDINFILTHY's Avatar
Question ls1 to a 700r4
i have a 72 chevy that i want to put a ls motor in and i was wondering if there is a plate or whatever to hook up to the 700r4 in the truck just curious if they make these conversions possible thanks for the input guys!!!!!
Old 12-16-2007, 09:31 PM
Gilbert@Ace Racing's Avatar
Well you will not need a plate in order to bolt it to the engine.
What you will need to concern yourself with is wiring up the lock-up solenoid to the controller and you will need to fab a bracket for the TV Cable to attach to the Throttle Body.
g
Old 12-16-2007, 10:27 PM
ok i can figure that out!!! so it is the same bolt pattern as a th350 and 4l60e
Old 12-16-2007, 10:31 PM
LS1Tech Sponsor
performabuilt's Avatar
Same bolt pattern but if your going to use the LS1 wiring harness why not use the 4l60e like came bolted to it would seem alot easier
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-17-2007, 06:07 PM
idont have a 4l60e just the 700 thats in it !!!!!
Old 12-17-2007, 07:07 PM
jay_lt4's Avatar
you will need a crankshaft spacer, either the Hughes or the gm spacer with longer bolts
