Manual lockup switch
Old 12-27-2007, 08:06 PM
super_fro_daddy's Avatar
Default Manual lockup switch
Can someone give me some info on doing this?? I have a PT4000 that locks up at 35. Alot of times thats too soon. I would like to be able to leave it unlocked around town since alot of the speed limits are 30-40 and the constant lock/unlock is annoying.
Thanks.
EDIT: I emailed "Larry" on here but also thought I would try here as well.
Old 12-27-2007, 11:25 PM
LS1Tech Sponsor
performabuilt's Avatar
You would need to delete the code for PO1870 and the tcc electrical code to do that and you would need to hook a switch up in series with the tan wire with the black stripe in the trans harness. This would allow you to disable it however you could also do this in tuning. If you need more info email me at performabuilt@yahoo.com and ill look it all up for you in the morning
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
