TCI 4L60E Problem?
TCI 4L60E Problem?
I have the superstreet fighter. i have been using for about 20k miles and ran perfect till the other day. i left the stop light and it would not shift to 2nd. Goes 1-3,4 put it on the lift and checked everything looks good ,perfect fuild.
Any help would be great
LS1Tech Sponsor
A1-3-4 Shift sounds like a possible servo issue, I would pull the servos and inspect the inner servo for damage if you sure you have 4th then that would indicate the 2-4 band is good. You also might check the 1-2 accumulator , But verify that you do have a 1-3-4 shift and not a 1-3 shift with lockup as this would seem to point to the band or a possible solenoid
__________________
