4l60e shifting issues when warmed up
i have a 99 camaro with a 4000 yank stall with 373. i intalled the the stall about 4000 miles ago and now when the trans gets warmed up it doesnt want to go into 2 hardly and wont go into 3 or 4th at all. When its cold it will shift into all gears no problem. what do you thing is my problem
What is the fluid condition and level?
Has your car been tuned for the gears and converter?
g
LS1Tech Sponsor
Need more description but there could be several thngs happening here, You could have a sensor such as the TPS failing when warm. Or the trans could be slipping when warm,
You also could have a solenoid failing thats heat sensitive . Do you have a check engine light?
__________________
