Performabuilt 4l80e installed
Well after along time having the tranny I finally got it all together and used a buddys lift to do it. The car still needs some shift programming and I need to alittle settings to do the lockup. I used some of my old pressure settings the lockup seems alittle funky but im gonna check all that stuff out the trans seems to shift real nice so far havent really beat on it but it seems to shift stronger then my 4l60's. Im gonna try some stuff tonite and see where im at and do some logging/programing tommarow. Ill post alittle list of some certain things I encountered during the swap probably tommarow.
Yea ill keep everyone posted and if I seem to have any questions maybe ill give you guys a call sometime I will be posted track results in about a month and most likely seeing what this can take. Does anyone have a base file of a 4l80e that I could start with. Im also glad I got my own hp tuners.
Yea sounds good id like to try and do alittle tuning and logging tommarow and try to get the speedo reading alittle better its close but I think it may be alittle off. Im hoping with a few minor adjustments it will all be good.
