Is there a procedure to determine the stall of a torque converter (out of the trans)
I tried to find some information on this before posting a question, but I didn't find what I was looking for. I recently purchased a TH400 trans that was rebuilt, but never installed after the rebuild. For whatever reason the seller didn't mention the stall speed of the torque converter, and I failed to ask. I know it's like asking for the world, but is there a way to determine the stall of the torque converter without putting the trans in the car?
From what I've read, I have to assume it's a lower stall since it's a wider diameter.
I know the name of the shop that rebuilt it. Is it common practice for trans shops to keep good records? I wonder if I called them if they'd have paperwork on the rebuild and know exactly what converter was installed?
I figured it was a BOP since all the info I could find online always showed the Chevy bellhousing. Since the trans doesn't mount up using all the bolts when mounting to an LS1, could these adapter plates from Jegs be used (even though it says they won't)? I assume that is says that since it won't be a direct bolt-on.
https://ls1tech.com/forums/showthrea...64#post7991464
