Which shift ket eliminates PWM?
I've been having problems with lockup at light throttle due to PWM. I've already set the min and max tables to the maximum values and that helped for awhile but it came back. I read there is a transgo shift kit that eliminates the pwm. Does anyone know which one?
Thanks,
Brad
Thanks,
Brad
LS1Tech Sponsor
The HD2 effectivly eliminates PWM or greatly limits it. It can easly be done however no matter which shift kit you use while the bodies down. However if your duty cycle is allready at 100 percent and it did fix it when you first did the change and its reapeared it could be a sign of a converter clutch issue or other converter cluctch/trans related mechanical issue also. But its definatly worth a try.
__________________
I'm gonna give the HD2 a try. I hope theres nothing wrong with the converter because it hasn't even had a thousand miles put on it since I got it from yank. Oh well I guess I will find out, thanks for the help.
If you have a chance take a look at this kit. http://finishlinetrans.com/store/pro...products_id=86
We also have some other things that I recommend that you upgrade while your in there.
http://finishlinetrans.com/store/pro...products_id=67
http://finishlinetrans.com/store/pro...products_id=77
