4L60E builders, i got a question.
Old 03-15-2008, 05:38 PM
spy2520's Avatar
Default 4L60E builders, i got a question.
What does this sound like:
New built trans,
brief rpm flare on the 2-3 shift at part throttle, full throttle i wont even try. Doesnt really feel like its slipping, but it feels like its applying whatever slowly.
D and OD leave me in what feels like 3rd gear, and it locks up in 3rd gear in either shifter position.
I dont think i've been into 4th yet, and i know in OD it should lock up in 4th, not 3rd. It pretty much does 1st - 2nd - 3rd - 3rd locked up in either D or OD.
Reverse is weak, it pulls reasonably on level surface. But if i gotta back up a hill it aint going. This might be ok though since the car has 4000 stall vig, and when i had a 3400 stall with my old trans reverse wasnt really a beast.
Also, this trans is supposed to be vacuum modulated but it shifts like a *****, part throttle, full throttle, either way. I guess i can try disconnecting the hose to test it, that should give full pressure right?
Old 03-15-2008, 06:32 PM
LS1Tech Sponsor
performabuilt's Avatar
Disconecting the vacum will give max line. The weak reverse is likley normal with the 4000 or at least it will feel that way . But overall sounds like you have low line presure. I would get a guage on it with the vaccum line unplugged and see what the presure is , I certainly wouldnt drive it much if at all till I solved the issue
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-16-2008, 05:28 PM
spy2520's Avatar
anything obvious that might cause this? Like something that could possibly be seen/fixed by pulling the pan off? hopefully i'll be able to get a gauge on it tomorrow.
Old 03-17-2008, 09:40 AM
spy2520's Avatar
let me guess, driving it like that seizes the forward clutches, among other things. Now all i need is a lift and a day off.
Old 03-17-2008, 10:29 AM
LS1Tech Sponsor
Yes low line presure can cause the forward clutches to slip/burn and even weld themselves together
__________________
Call 888-744-6542
Old 03-18-2008, 11:14 PM
SMALLBLOCKHERO's Avatar
what happens if you leave it off? will it hurt it?
nice deals with the layaway plan by the way. got me lookin now.
Old 03-18-2008, 11:17 PM
LS1Tech Sponsor
Not good to leave it off, Max line all the time very hard on the hard parts
__________________
Call 888-744-6542
