TCI Max Shift RTF Racing Transmission Fluid
Even with a tranny cooler I get up to 200 degrees after 2 passes on the track during the summer so I'm looking into ways to keep that temperature down. The TCI Max Shift RTF Racing Transmission Fluid writeups say it reduces temps by up to 30 degrees. Is anyone using this and seen that kind of results?
and what effect would this ATF have on a daily driver? I did read this: "Max Shift RTF, or any aftermarket tranny fluid for that matter, will not work in certain newer-model transmissions, such as post-'04 Fords and the '07 Dodge Cummins". So is this ok in a 4L60E?
