Trans Temp Sender
Trans Temp Sender
Can some one out there who has fitted a Trans temp gauge please tell me where they have fitted the sender unit?. I have been told that drilling and tapping the gearbox pan is the way to go, or putting a t-piece in the "out" lines to the cooler (after market cooler being fitted also) or in some hole on the gearbox for line pressure testing also works?
I'm planning to get a TCI Deep Pan so I don't want to damage it with drilling and tapping.
Just mount the sending unit in the pressure port on the drivers side of the transmission. People say not to do it b/c the trans temps will be off. EFI live actually showed my trans temps to be colder than what my sending unit off the pressure port read. I would rather be seeing hot false temps than cold false temps.
I would not put a "T" in your cooler lines, as it can restrict flow to your cooler. Put it in the pan, or the pressure test port thats on the driers side of the trans. I'm going to put one in the pressure test port eventually.
