yank ss 3600 and traction
Old 03-23-2008, 11:02 AM
mywhite02taws6's Avatar
Default yank ss 3600 and traction
i have a 2002 a4 trans am and i have o.e.m corvette rims 19'' rear 18'' front on ttoyo tires. wondering if getting the ss 3600 stall will i have a problem on traction, also getting 3.73 installed, true dual exaust,tr224 cam thanx
Old 03-23-2008, 11:15 AM
will all this application be to much for my stock tranny? will i need to build it before all this?
Old 03-23-2008, 11:17 AM
dameter21's Avatar
stock tranny will be fine. I know guys that have even bigger stall with power and also spraying stock tranny and not one as had any problems.
Old 03-23-2008, 12:02 PM
bumpp
Old 03-23-2008, 12:05 PM
caldercay's Avatar
Pick up the phone and talk to Dave at Yank - he'll give you the definitive answer.
Old 03-23-2008, 12:13 PM
99Hawk262's Avatar
Yes, traction from lower speeds will be non-existent unless you run a good tire. Nittos work well on the street, and MT ET Streets work awesome at the track. I run regular street tires on a day-to-day basis and my car will break loose at 50 on a cold day. Might be that PT4400 causing that, but you get the point!
Old 03-23-2008, 02:25 PM
Pontiacerator
RevGTO's Avatar
SS3600 + 3.73's + WOT + 1st gear + street tires = smoke.
Old 03-23-2008, 04:12 PM
CamaroRacing12's Avatar
= Bada$$$$$$!!!
Old 03-23-2008, 05:19 PM
JScamaro's Avatar
1st gear has no traction for any stalled A4 on street tires.
Old 03-23-2008, 07:05 PM
my rear tires are pritty wide they are the same as stock c6 corvette wich comes like 400hp i believe, so my tires wouldn't handle a 3600 stall at 1st gear, does anyone know any stall or str i could get that i could keep my tires, they cost me $1000 and i don't want to have to change them
Old 03-23-2008, 07:09 PM
RamAir02TA77's Avatar
Uh with a stall your probably not ever going to get traction in 1st on street tires.... If you want to race get a good tire your not going to be burning the tires off everywhere just drive normal.
Old 03-23-2008, 07:19 PM
slimcracka's Avatar
this guy is right, and sometimes depending on the dr..and how cold it is out side...ive got mine preaty much hooking on a warm day from a dig. but with a 315 bfg and a lil susp. mods... just got to play with it
Old 03-23-2008, 08:27 PM
Ragtop 99's Avatar
You'll need to learn to control the throttle instead of just mashing it. 3.73s definitely will make it easier to spin.
Old 03-24-2008, 12:04 AM
JScamaro's Avatar
You can still keep your tires if you go with the Yank. I have street tires for daily driving. You'll just have to go easy in first then hammer it.
You can always get two extra wheels and mount drag radials on them for when you really want to go fast.
Old 03-24-2008, 12:28 AM
LS1Tech Sponsor
performabuilt's Avatar
Its really amazig to me technology give you more power . But when it comes down to it all that matters if what you can put to the pavement
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-24-2008, 02:17 AM
SMALLBLOCKHERO's Avatar
i just got my SS3600 and the 3.73s. installing in 2 weeks. hope the 10 bolt dont die tooo soon.
Old 03-24-2008, 03:00 AM
allbaugh_04's Avatar
With 19" rims, you will not get traction with a stall. That's a fact....you might want to get another set of rims with some drags or drag radials. Or your tires will be gone
Old 03-24-2008, 05:31 AM
im not gonna take off the rims or tires, if i stay with 3.23 and go with a 3000 stall will it make it easier to get traction. I understand what you guys are saying about not mashing on it but by doing that is there even a point of getting a stall in my case? thanx for all opinions
Old 03-24-2008, 05:44 AM
i guess i may not get a stall now, so with just full exaust and lid with stock stall and 3.23 is a tr224 cam ok or pointless? or would it be more wise to get a smaller or cheater type cam
Old 03-24-2008, 08:18 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
You want to match the cam to the gears and the stall. If done right the 3 can form a killer combination.
Quick Reply: yank ss 3600 and traction
