4l80e Swap:Shifter Wiring Question
Here are two pics of a stock f-body shifter I just installed in my m6-->4l80e swap in my 2000 Trans Am.
Passenger side view:
http://i173.photobucket.com/albums/w...m/DSC02882.jpg
I believe this is is the six pin connector. Top two pins are park/neutral switch.(I will tie in clutch switch wires to these 2.) Middle two are the reverse lights.(I will connect lightgreen and brown connector wiring from t56 to these) Bottom two are for the pcm to tell it how to idle i believe whether its in drive or not...(Do I need to care about wiring to these?)
Can I get a plug for this 6 pin connector then splice on the wires? Or how have you guys connected to these..solder? Plug would be easiest.
Driverside View:
http://i173.photobucket.com/albums/w...m/DSC02881.jpg
There is what i believe a two pin connecter in the upper left of the picture. Any idea whats that for and if i need to wire to it?
Driverside View:
