4 or 5 pinion planets?
I am getting a 4L60E built here in Aus and asked them to use the same spec parts as the sponsors Level 3 builds. Most bulders here are stating that 4 pinion planets are stronger than 5s, doesn't make sense to me.
Is there any basis to their statements?
LS1Tech Sponsor
I was told that the 5 pinion planets arent a complete necessity and are mainly needed in applications where towing will be done.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
LS1Tech Sponsor
5 pinion planets have a little more surface area for load in the pinion area, However from what I have seen the area most likley to fail under performance stress are the splines in the center and they do not appear any stronger in that area, I can tell you that if you do use them get only OEM GM 5 PINION PLANETS. Not the aftermarket cheapys
__________________
