please help car might die :(
Old 03-28-2008, 03:38 PM
munecorey's Avatar
Default please help car might die :(
I posted back asking if i should do a trans service on my 98 a4 trans am, because it had a risk of not working again. Well yesterday i went to have a tramission service, and it ran kinda weird, but today i went and started the car, it had trouble starting, then 6 hours later i go to turn it on again and the engine would not start, tried it like 5 times, and if finally started after i hit the gas. So is this normal to happen after you do something like that, or is my car going to car heaven?
Old 03-28-2008, 03:45 PM
LS1Tech Sponsor
performabuilt's Avatar
Well a trans flush would not cause the car not to start , Sounds like a coincidental problem just happened to show up at the same time, But you might need to have car scanned you could have a bad coolant temperature sensor perhaps
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-28-2008, 03:58 PM
munecorey's Avatar
Well i feel a little more relived, But i dont believe in coincidences, im going to get the car scanned, and see what the problem is!
thanks for the advice!
