Trex,ms4,vindicator,f14 etc..with th350/400?
Old 03-29-2008, 11:17 AM
lilicedout24's Avatar
Question Trex,ms4,vindicator,f14 etc..with th350/400?
ok just wanted to see what kind of gear you guys are useing and et results. i heard all the stories bout 400 taking away power etc... but is it affecting your 1/4 times. i have a few buddy that really want to do a few of these cams in this size range and just curious on some results thankx for any input.
Old 03-29-2008, 01:29 PM
so no one running these with a3
Old 03-29-2008, 02:19 PM
DanZ28's Avatar
I was running a TRex and TH400. I ran a 4.10 gear but probably would have been better suited with a 4.56 gear since I went through the traps at 6300 RPM. Stock cubes running N/A my best trap was 126 mph and best ET was 10.74. 1/8 th was a 6.84 @ 101 mph.
Dan
Old 03-29-2008, 05:49 PM
Dan
man nice # was car full weight
Old 03-29-2008, 08:47 PM
DanZ28's Avatar
Thanks!
I pulled out a little weight (AC, PS, ABS, spare tire, rear seat, passenger seat) but also added some back with the 12 bolt. It was 3500 with me in it. I could have went 10.5's or better with a couple hundred pound weight reduction and 4.56 gears for a better 60', best I mustered was a 1.54, which is shameful off a T-brake, I should have been low 1.40's. All behind me now, going turbo.
Old 03-31-2008, 03:14 PM
trigger1's Avatar
I am currently putting together a car with a Tbraked TH400, MS4, stock cylinder head, 4.33 geared 9" rearend. I'll post up results as soon as we hit the dyno for tuning then the track.
Old 04-02-2008, 07:49 AM
oh ok keep us posted
Old 04-04-2008, 11:15 PM
bump any more guys
Old 04-04-2008, 11:38 PM
silverbeast's Avatar
My budies car is a cam only ( t-rex) w/ 4.10's ,th350 and pretty much full weight minus the spare tire, front sway bar and the inner bumpers and has mufflers just off the headers... he has went 11.00-11.teens n/a and a 10.34 @ 128 on a 150 shot.
Old 04-05-2008, 10:28 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Hopefully it will stop raining so I can get some baseline numbers
Setup below
PRC Stg 2.5 5.3 heads
Magic Stick 3
Forged rods and pistons
Victor Jr with 750 AED carb
TH350 with 3500 stall
stock 10 bolt with 4.11s
Following has been removed
Front bumper brace and foam
All A/C components
Power Steering
Front sway bar
PCM and wiring harness
Passenger and rear seats and belts
Spare tire and jack
Cruise Control and TCS
Old 04-05-2008, 10:41 PM
dochall22's Avatar
I'm running trex and th350 - no times as of yet - but i'll pull a lot harder than Z/28 2002s TA!!!
Old 04-08-2008, 10:28 AM
thats great #'s wish i could see times like that
Old 04-08-2008, 10:29 AM
Thumbs up
O O sounds like race wars!!!
