Transmission died...... have to replace torque converter?
Last week while on the freeway my transmission finally went out. It happened when i decided to gun it while emerging from the on-ramp to the freeway. I notice that i needed to gain speed because everyone was flying on the freeway. Right after i gunned it, it shifted like it was suppose to then it just slipped and went straight to what felt like neutral. Right after that, i knew it was gone. My question is, do I have to replace the torque converter as well? Or can it be flushed out clean?
Chris
It is usually suggested to cut and clean your converter, to be on the safe side. The only time I would not suggest a Cut & Clean is if something like the sun-shell broke and there was no metal contamination. It sounds like something is slipping and/or burnt, which means debris are circulating in you fluid. In my opinion it is not worth the risk of contaminating a fresh transmission. What type of converter are you running??
Chris
Chris
Im running a TCI street fighter 3500 stall. I checked my tranny fluid and it is the color of motor oil now (light brown). Not the red color anymore! so yea.... my tranny went! Where do I go to get my converter cut and cleaned? can the transmission shop do it themselves? Or do i have to send it out. thanks for the info
