Got my 80E in.... a few bmr cross member questions
Old 04-02-2008, 01:07 AM
Sweet71's Avatar
Default Got my 80E in.... a few bmr cross member questions
So my buddies and i installed my 80e today, went in pretty well all said and done, only thing i noticed that was a little weird is that the bmr cross member seems to be a little crooked, bolts holes were a little bit of work to line up, is this common or has anybody else ran into this?? As well the lokar 36 inch 80e dipstick did not fit in i had to take a couple thou off the end to get it to fit into the case, besides that just used the trans mount off of my 60e, its a energy suspension 3.1108g seemed to fit well. Any oppinions on the cross member issue would be appreciated, thanks again guys!!
Old 04-02-2008, 08:12 AM
nahasapeemapetalon's Avatar
Yes, mine was a pain in the but, one thing i found worked well is i turned around the tranny mount, that made all the difference. Made the stud on the tranny go in the crossmember hole. Even after taht i ground a lil corner off the back of the tranny where it hit the crossmember. It does seem crooked, thats how its designed.
My 36" lokar fit, i gotta get it secured better in the engine bay, whatd u do? OH, as well i ..with a hammer, bent the back pass. side corner forward enough so it would clear the member.
Good luck.
Old 04-02-2008, 10:19 AM
Sweet71's Avatar
Im gonna mount the upper side of the dip stick on the cowl of the engine bay under the plastic there is a nice ammount of metal, fits pretty good!!
Old 04-02-2008, 11:17 PM
dkbykesdk's Avatar
x2 but i have a th400
