A4 > th400...Wiring?
4 cars, connect these wires together
purple + dark green = neutral safety switch, must be done to start vehicle
orange w/ black stripe + black wire = hatch release to work.
The brown and light green wires should NOT be wired directly together. Doing so will cause your reverse lights to stay on at all times. You can run them threw a momentary switch or just leave them apart like i did.
I found a dark green and purple, but they go to the little two lead connector...I though it was the speedo. Are those two right?
Also, the orange+black...I can't find the orange. There's more of a tan looking wire with a black tracer...And that the closest thing to orage. Are these two the right wires as well?
edit: 01 Formula
