low buck glide
low buck glide
I can get a working chevy powerglide from a 60's wagon for 75 bucks.Can it be built as cheap as a tubo 400 to handle about 750hp?I have a turbo 400 I was going to build soon but came across the glide car is going to be 80% strip 20% street
You need to know if it has a stamped steel carrier or a cast iron carrier.
The stamped steel carrier has 1.8x gears while the cast carrier has 1.76's.
The stamped carrier won't handle that sort of h/p very long.
We build glides all the time that can take what you are putting down. The basic build starts at $950.00 and goes up from there depending on your budget and needs.
Give me a shout if you are interested.
g
g
