carb and a 4L60E
Old 04-26-2008, 02:11 AM
JohnFrazee02SS's Avatar
Default carb and a 4L60E
i plan on putting together a street rod with a carbed 5.3 and i have an extra 4L60E what do i have to do to make it work?
Old 04-26-2008, 01:17 PM
Gilbert@Ace Racing's Avatar
It needs to be converted to Full Manual.
Then, you'll need to add a Converter Lock Up toggle switch and Manually control lock up.
If you need help with this give me a shout.
g
Old 05-01-2008, 05:48 AM
sounds like it would be pretty badass that way though is that by changing the valve body? how does the switch work? and about how much that trans needs a rebuild anyway
