can a stall cause this problem?????
I put in a ss300 and about 700-800 miles later my car keeps throughing a code p0332 knock sensor 2 low input. If it cant then i need to know what to do to fix this cause this i hate having a check engine light and having to pull the scanner out every 2 times i drive the car. Please help guys!!!!
Not really sure on the code but it you have a vibration it could be an issue. I have seen in C5 corvettes where the shaft that goes through the torque tube has been left loose and triggered a knock sensor code. Any noise or vibration present? Have you done any test to verify if the knock sensor is good or reading properly?
no knocking that i can hear and like i said i just had the trans gone through and stall installed and drivin about 7-800 miles, so i dont know if there may be a pinched wire or if the sensor is just bad or what.
