Aluminum Driveshaft
Old 05-07-2008, 09:55 PM
losiguy's Avatar
Default Aluminum Driveshaft
Would a aluminum drive shaft from a M6 with a 1350 yoke work on a 4l60E with the stock 10 bolt? Thanks.
Old 05-07-2008, 09:56 PM
losiguy's Avatar
still looking
Old 05-07-2008, 10:39 PM
c0ncEpT's Avatar
I dont know about the yoke but I know a 6 speed and A4 drive shaft are the same length in 4th gen Fbodies
Old 05-09-2008, 08:52 AM
pddye's Avatar
The 1350 I believe is to big. It should be wider and have bigger cups than stock. Other than that just change the rear joint and you should be good to go.
Old 05-09-2008, 09:29 AM
Stroked96Bowtie's Avatar
Correct...1350 wont work on a stock 10bolt. Aftermarket rears require them.
