Vig converter universal for all LS 4l60e's?
Just wondering if a 3600 vig converter out of a 99 4l60e will work on a 98
4l60e. It looks like the input shafts are different on the transmissions. Also, are all the 4l60e's for different years on fbods interchangeable? Thanks
LS1Tech Sponsor
The LSX versions will swap . I the 98 is and LSX then yes it will swap if not it wont, Simple way to tell if the shaft is flat on the end and the oring is just behind the splines then its and LXS If theres a smoothe tit on the end of the haft with the oring on it its and early style non lsx and will not swap
__________________
