new trans is shuttering in overdrive
my new performabuilt lvl 2 is in i drove it today to make sure it was working ok all is fine except when in overdrive and locked up i push on the gas and i feel and here it shutter the car has a yank 4000 stall converter i hope i am not killing another tranny the noise is less than a second
LS1Tech Sponsor
You need to determine if lockup is still on when you do that, Try ligtly applying the brake to disengage lockup with one foot while accelerating with the other and see what happened sounds like its shuttering as lockup clutch is disengaging on acceleration
__________________
yes lock up is ingaged when it does it other than that the trans works awesome i am very happy with both my purchases from performabuilt and will recamend performabuilt to any one who needs a transmision thanks jason from iowa
