Part throttle shifting...
I just had a built 60e installed. Just normal take off from a stop sign it shifts into second at like 1700 rpm and around 6 mph. Then shifts into drive around 15 mph. Is this normal or is something off?
LS1Tech Sponsor
Would depend on your gear ratio in rear and of course if theres a cam that can affect things to. Did you do any other changes when you installed new trans? The 4L60E shift time is strictly a matter of programing , It can only do whats its told so not likely a trans issue per say but more likely a tuning issue if theres a issue at all , Would need to know a little more about the swap and your car , That does seem a little low though IMO
__________________
