th 350 LINKAGE ????
th 350 LINKAGE ????
I am putting a 350 in my 98 trans am and am using the stock shifter. i have read that you drill a hole in the center of the other 2 holes and it lines up perfectly with the pan bolts. mine does not line up right. i can go a little forward or backward with the bracket but it limits either park or first. is there any adjustment on the stock stifter so i can adjust for park. thanks
