TH 350 - shift up and down 2-3 permanently
Hi,
I have an Impala 350 cui with a TH 350.
Since a couple of days the tranny shifts up and down two times a second. I have the feeling that this is mostly the case when the engine is hot aftewr 10 miles.
I have changed the oil and the filter, and the oil level is correct.
What yould be the reason for my problem, what can I check?
James
James
I removed the detend cable and I still had the problem. I think a TH 350 do not need a detend cable, because it is only necessary for downshift. Is this correct, so can I do something wrong by adjusting the detent cable?
