sprag question
Old 08-06-2008, 07:16 PM
chad rock's Avatar
Default sprag question
I got the parts to fix my turbo 350(new sprag drum assembly).the outer race on sprag seems kinda hard to turn counter clockwise. is this normal?
Old 08-06-2008, 07:34 PM
LS1Tech Sponsor
performabuilt's Avatar
It should have a little resistance one way possibly with a sqeaking sound and be impossible to turn the other way
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-06-2008, 07:51 PM
FLT
FLT's Avatar
If it is a one way roller clutch, then it should squeal like Frank has mentioned. If it is sprag style clutch then it should not squeal. I do agree that they all have a degree of resistance when being turned in the freewheel position. I have seen some aftermarket sprag drums that I did not like the way they turned. Mostly from improper machining. Maybe take it apart to take a look or call who you purchased it from to see what their thoughts are. Vince
Old 08-06-2008, 07:55 PM
WE TODD DID's Avatar
If its a segment sprag, make sure you have it on the correct way, or it will flip it, and you'll never have 2nd gear.
Old 08-06-2008, 09:00 PM
chad rock's Avatar
thanks it just seemed like it was a little too much resistance to me but I dont know a thing about transmissions.I asked people who sold it and they said it should be fine
