Front seal leaks
Front seal leaks
What are the chances of getting it to stop by just replacing the seal?
The trans has 35,000 on it, at 28,000 I had it apart to put the whole TransGo kit in and a TCI converter. I later put the stock converter back in.
It had a slight drip every time. Last time I changed the pump gasket, o-ring, and seal. I did a M6 swap and it sat.
Now it's back in another car, if i drive it every day it might drip once. If I let it sit it leaves a puddle.
I know it's the seal, it's a timken from autozone.
What are the odds it'll not leak without changing the bushing?
Guess I'll order the parts.
Thanks.
