4L60E Swap...98 Suburban into a 96 TransAm
Old 08-09-2008, 05:17 PM
BlackTA96's Avatar
Default 4L60E Swap...98 Suburban into a 96 TransAm
I have a transmission out of a 98 suburban and i wanna put it in my 96 transam
I think it'll work if i just swap out the tail shafts....is that right??
I had someone tell me it won't work.
Old 08-10-2008, 11:10 AM
BlackTA96's Avatar
...ttt....
Old 08-10-2008, 12:00 PM
BlackTA96's Avatar
Well I just looked at the suburban trans again and its got some electrical connectors up by where the shifter connects...i don't think my trans has those connectors...can anyone help me out with this?????????
Old 08-10-2008, 02:27 PM
FLT
FLT's Avatar
I believe the case is different on the two transmissions and also the shifter linkages. Your fbody has a case where the bell housing is not removable and the suburban has a removable bell. Not sure if this is going to work for you without a bunch of headaches. The wires that you are seeing are for a neutral safety switch or a PRNDL switch.
