TH-700r4 tranny to LSx engine.
I just want to double check and make sure i have researched this properly, sense i'll probaly be using the 700r4.
To put the 700r4 to the LSx ( im actually doing it to a 5.3 vortec) with a LS1 flexplate, 700r4 stock converter.
I need Additional:
LS1 Flexplate Spacer 12563532
http://www.crateenginedepot.com/stor...2-P1343C0.aspx
( quanity of 5 ) LS1 Flexplate Spacer Bolt 12563533
http://www.crateenginedepot.com/stor...3-P1344C0.aspx
And the Adapter goes on AFTER the flexplate?? so it would be from left to right.
Engine - Flexplate- adapter - bolts - converter.
is that correct?
I need Additional:
is that correct?
