Misfires killing trans
Can a prolonged misfire cause the transmission to loose the 2-3 shift? I had the plugs replaced while I had a converter put in almost 2 years ago.The trans lasted about a year after that,the whole time I had a misfire code and heard that a lightweight converter would do that so I didn't think much of it.I lost the 2-3 shift and had it overhauled and put the stock converter in.Now 18 months later I have the same problem. While chasing down a loud tick that I thought would be a broken rocker I found a a sparkplug so loose that I was able to take it out by hand.
So what do you guys think?
