Output Shaft Play
Output Shaft Play
I have broken 2 tailshaft housings. I bought a TA relocation bracket. The new tailshaft housing is perfect even after a couple track days because of the TA bracket. However, i noticed my housing seal leaking. I took out the driveshaft and noticed that the output shaft has noticable play in it. What is the cause of this? Do i need to tighten it? Is something seriously broken in my trans? The trans shifts fine and appears normal aside from the leak. I would think that since the driveshaft was out and i could wiggle the output shaft that the diveshaft should be fine as far as balancing is concerned. I really need some help. I am getting tired of fooling with these tailshaft housings.
