Launching with a stall
I am in the process of building up my second gen and needed some advice for a stall converter.
Its a street car with the occasional track day. The motor will be making around 400-450. It will have a set of 3.42s. I originally was looking at a 2400 stall but now am leaning more towards a 3000. Its a th-350 and my question is if i get a bigger stall will it still be streetable and with a higher stall will that just blow the tires off on the line?
thanks in advance
thanks in advance
I'm sorry, I don't have an answer as to why they are pink but reading this made me laugh. Maybe the guys over at PI really like the color of bubblegum . I've been trying to figure out what stall won't destroy my street tires too, although we are in 2 completely different situations..best of luck!
I daily drove a 3600vig with 3.73's for 2 years and loved every second of it. Id go higher then a 3000. Its easy to blow the tires away if you want to but you wont if you don't mash it.
LS1Tech Sponsor
Torque Converter
At FTI Competition Converters we can build a converter that will drive
like a 2500 rpm stall but actually stall at 3200 rpm. We do this by running a little lower Stall Torque Ratio. This also helps keep the tires planted on the launch as it does not hit so hard.
Let us know if you have any Questions as we're here to help you.
You can call us Toll Free @ (866)726-8358 or email us.
Thanks
Thanks
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
Look at our website
www.converter.cc
you will find all the info you will need or call us at 775 826 9955
www.converter.cc
i did take a peak at your website but only saw things for the 4th gens
edge 3200 here...... but, more importantly what's your motor details, vehicle weight, tire you will be using etc etc. surely we would need that info for anyone to suggest a stall speed.
th-350 red eagle clutches, shift kit, deep pan, cooler.
8.5 differential with 3.42s and eaton posi
weight is 3600 lbs.
current tire is a 225/70/r15 (will have a set of track tires not sure on the size and will be getting a wider set out back)
This will be my dd but only for 6 months at the most
thanks again
10 & 11 Second Club
Thanks
Thanks
My 3800 FTI drives like a 3000 stall on the street but runs 1.45 60' at the track with sticky tires.
Dave
LS1Tech Sponsor
Launching With A Stall
Bud here at FTI Competition Converters . We build high performance converters for applications like yours , and our customers love them. Just a couple things that I didn't list in previos thread. When you buy one of FTI's Converters it's the last one you have to buy if you change your combination we will restall your converter for free up to 3 times to the original owner.
Also all of our converters come with Satifaction Guaranteed . Let us know when we can help you.
Thanks
FTI (866)726-8358
Thanks
FTI (866)726-8358
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
Every FTI is built to your combo.....not off the shelf, and the performance is second to none. We have run one of the top winning teams in the big$ bracket circuit throughout the Eastern US and have installed, run, and raced most of the known brands through the years and the FTI is far & away the best we have seen not only in performance, but the service & turnaround if a restall is needed.
Last LSX shootout winner runs a RevXtreme/FTI:
And Marc Fishers Vette cover bracket car:
The expolded view display...so there is no doubt as to the quality that goes into these converters:
