Need Advise. Poor Audio from CD 05V.
Threw a CD in my 05 deck and played normal for a few seconds then it became very subdued. Do you think it just needs a cleaning? Would you recommend the cleaning CD with the felt brush?
A cd is digital, the radio will either be able to read the 1's and 0's or it won't. Worth a shot cleaning it, but I personally doubt it will fix the issue. I couldn't begin to guess what else it would be.
As stated, if your player needed cleaned, the quality wouldn't necessary be bad, but it would skip and/or be 'glitchy' sounding. Big difference.
If the quality seems to have dropped, perhaps there is a problem elsewhere with the amplifier or speakers. How about the radio, does it sound worse than it did as well?
I would guess that you have a loose connection between the cd player section and the main amplifier section. I have never taken one of these apart but I would guess that there are a couple of boards in there. Could be a wire or solder joint that has failed and is just not making a good connection. I know between here and the other board I have seen pictures of this radio taken apart that you could use as a reference to see if you want to tear into it or not.
